Engine Timing
Old Aug 13, 2007 | 06:37 PM
mojo2go's Avatar
mojo2go
Default Engine Timing
This has probably been asked before but I searched around and did not find any info - On an electronic ignition setup like the one on my '81 XLS, how or what advances or retards the timing?
Old Aug 14, 2007 | 10:59 AM
Doc 1's Avatar
Doc 1
Default RE: Engine Timing
The breaker plate in the nose of the cam cover will change the timing. You might have to drill out therivits on the cover to revel the plate...you will see a plate with slotted mount holes and ADV stamped in it with an arrow pointing in the direction of advance....each one of the lines stampedin the plate repesents 2.5 degrees movement.
Good Luck
Old Aug 14, 2007 | 06:21 PM
mojo2go's Avatar
mojo2go
Thanks for the info
varider12$
2014-2024 Touring Models
Apr 12, 2017 06:54 AM
DeneFXDWG
Jan 7, 2017 10:54 PM
No U Glider
Dec 2, 2016 10:30 AM
kevinrdc
May 3, 2013 08:51 AM
98glider
Shovelhead
Dec 15, 2010 05:31 PM
