Spark Plug Wires..??
Old Jan 29, 2023 | 04:40 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by FLTRI17
Without question trouble free operation with stock plugs and wires. No need to purposely add a variable (resistance) into the engine management system knowing the ECM has its own lookup table to determine combustion quality based partly on the plug and wire resistance.
Have found NGK 4179 to work ok and has a solid top like the stock plug so it can’t come loose and alter resistance readings.
Bob
With ion sensing I would not use an NGK 4179, I have in the past and have found up to 5° knock retard because of detonation while data logging... At least the system thought it was detonating but there was no evidence on the plugs but yet my timing was being held back.... Stick with the 6R12...
roadking01@
Jan 10, 2023 01:08 PM
Ndoggct
Sep 21, 2016 07:02 PM
ro9beam2002
Nov 28, 2011 10:37 PM
paintballoma
Jun 6, 2007 11:18 AM
zenwarrior
Aug 30, 2006 03:56 PM
