Intake I.D.
Old Feb 24, 2023 | 11:41 PM
HillbillyRick's Avatar
HillbillyRick
Looks like a small velocity stack. Should help with the low end...
could it hurt high end. I found it impossible to get it up to 100 mph. It pretty much won't go higher than 95
Old Feb 25, 2023 | 09:51 AM
98hotrodfatboy's Avatar
98hotrodfatboy
It's hard to say without putting it on the Dyno.. If it does I don't think your butt will feel it.. I know some shops will dyno without the Air cleaner on just to produce better flow at higher rpm's to get that peak number up.. Take a test hit without the AC on and see what it does.. Just mind your breathers so it doesn't make a mess of the bike.. You can take 3/16" vacuum line and just temporarily route it to the ground, just secure it.. Or maybe you can just remove that one piece and reinstall the whole AC..Then try it..
Old Feb 25, 2023 | 08:36 PM
HillbillyRick
Default Thank you
thank you! I'm going to rout to a catch can or something. I think I want to keep the oil out of the TB.
Nick1150
2018+ Softail Models
21
Apr 23, 2021 07:20 AM
MegaTron
Softail Parts
Aug 1, 2020 01:54 PM
MegaTron
Aug 1, 2020 01:45 PM
LACOUNTRYHICK
Mar 30, 2011 01:02 AM
