FP3 air fuel ratio tuning with cams
Old May 9, 2023 | 06:40 PM
sjones73's Avatar
sjones73
Default FP3 air fuel ratio tuning with cams
I have installed a set of S&S 551 easy start cams. I now have a low idle tick. Goes away at even a little off idle. (barely any throttle at all)
I double checked everything as far as tightness etc. All is good.
Wondering if I should kick up my air/fuel ratio on my FP3? (setting 17) It is set at 0 right now. Bike gets hot FAST.
Wondering if anyone has had experience dealing with this issue.
Thanks.
Old May 10, 2023 | 08:30 PM
Max Headflow's Avatar
Max Headflow
Typically when you have a low idle tick, it's a weak lifter but with the easy starts it might be the bob weights in the cam that open the exhaust valves.
Old May 10, 2023 | 09:58 PM
sjones73's Avatar
sjones73
I have messed with the FP3 air ratio. Didn't fix it.
Max, you might be right, so going to put some lifters in it and recheck all other things. Should have probably done lifters with new cams from the start. ugh
I will let you know what happens.
Old May 11, 2023 | 09:02 AM
porkster's Avatar
porkster
I had an issue with lifter tick on a 106” twin cam with the Easy Start cams a few years back. After ALOT of time and money, for me the cure was the Axtell bypass kit..
https://www.zippersperformance.com/w...pass_valve.pdf
NO4NJNK
Jan 18, 2021 01:28 PM
slammed05fatty
Dec 15, 2014 07:25 AM
arkstreetbob
Oct 5, 2011 03:51 PM
troop
Dec 19, 2009 12:28 PM
hd2000
Exhaust System Topics
Nov 11, 2007 12:46 AM
