Fuel issue
Old Jun 1, 2023 | 03:02 PM
Jojoe's Avatar
Jojoe
3rd Gear
Default Fuel issue
Need help!! I have a 2008 Sportster 1200. Fuel injected. At low speeds, 40 mph or less, it feels like I'm running out of gas. I use high octane gas, I've replaced the air filter, sparkplugs, fuel injectors, fuel sending unit, (fuel pump, filter, pressure regulator) Nothing seems to work. Any suggestions?
Old Jun 2, 2023 | 06:56 AM
MyFavRk's Avatar
MyFavRk
Have you tried cleaning your IAC , should be done at every service interval . Remove your air cleaner , place a rag inside the TB , with the ignition on , if you toggle your off / run switch ( do not start ) you'll notice the pintle retract . Get some throttle body cleaner ( not carb cleaner ) and spray up into the hole , the rag will catch all the crud . After you clean out the iac , clean the butterfly and throttle body seat .
Old Jun 2, 2023 | 01:04 PM
marcodarq's Avatar
marcodarq
test your fuel pressure and report back. if you can not test it due to lack of tools or know how, take it to a shop with a good rep.
m
Old Jun 2, 2023 | 01:39 PM
Lonewolf176's Avatar
Lonewolf176
Won't fuel pressure issues usually present in higher rpm's? is the bike stock? Tuner?
Old Jun 3, 2023 | 01:35 PM
marcodarq's Avatar
marcodarq
EFI 101, when trying to diagnose an engine performance issue on a fuel injected motorcycle, that runs, test and confirm that fuel pressure is in specification.
you do it early in the process so that it doesnt come back to bite you in the *** later. low fuel pressure or intermittantly high and low pressure can present in lots of different ways, from no start to all kinds of performance issues.
m
Old Jun 4, 2023 | 08:20 AM
bustert's Avatar
bustert
there could be many issues or combination there of.
if your system uses o2 feedback, then an o2 sensor could cause the issue also.
best bet is data logging.
checking fuel pressure is always a good idea.
machine throwing any codes?
i ride gravity, it never fails
Bone78
Jun 6, 2022 06:36 AM
tonyd2017
General Topics/Tech Tips
May 18, 2020 05:07 PM
trackadaptor
Aug 18, 2010 02:31 PM
blackcrowe
Jun 11, 2008 02:34 PM
Jase
VRSC Models
Jun 8, 2008 06:26 PM
