2008 Ultra classic fuel issues
Old Jul 17, 2020 | 11:03 AM
Bone78's Avatar
Bone78
5th Gear
Default 2008 Ultra classic fuel issues
After 1/2 a tank I'm losing power and the bike runs poorly. Obviously i need to look at the fuel filter/housing. Other suggestions?
Old Jul 17, 2020 | 03:33 PM
btsom's Avatar
btsom
How many miles on the bike, how many miles on the fuel filter? Has it ever sat for an extended period. Typically 4 causes for your problem. 1. A pin hole in an in the tank fuel line. The bike runs well enough until the fuel level drops below the level of the pin hole, and then starves for fuel. Next time fuel gets low enough for the problem to happen, remove the fuel cap, turn on the switch (including the run switch) and look into the tank to see if fuel is swirling around while the pump is priming. 2 Way over due fuel filter replacement. 3 The sock on the bottom of the fuel pump plugged up with dirt or wax and tar from spoiled fuel after sitting for a couple of years or more. 4 Cracked fuel filter basket (also will show swirling fuel inside the tank.) Listed in order of likelihood based on your symptom, but the last one still might be the cause.
Old Jul 17, 2020 | 04:57 PM
Bone78's Avatar
Bone78
5th Gear
I purchased the bike last summer with 21k it has about 27k on it now. I know nothing on the previous maintenance , but milage indicates it sat a lot. On one of the many top off yesterday i did check to see if i could see fuel spray in the tank when i cycled the pump. I saw a drop fall at the end of the pump cycle but no spray or swirl. Going to pull the filter tonight. Made for a long ride home.
Old Jul 17, 2020 | 05:28 PM
dawg's Avatar
dawg
Replace filter and filter shell and check the regulator real well. The shells were recalled in 2008. The regulators and the hose attached to can come loose.
Old Jul 22, 2020 | 09:53 PM
Bone78's Avatar
Bone78
5th Gear
Pulled the filter tonight. Before i disconnected i cycled the pump. Looks like the regulator if bypassing all the time. I would expect it to release pressure at the end of the cycle or am i wrong. Filter looked dark but not dirty. Filter and housing on order.
Old Jul 22, 2020 | 10:20 PM
Mr. Mike's Avatar
Mr. Mike
Hopefully it’s something simpler than the tank liner peeling. 1/2 tank of fuel remaining? Sputtering? Does flipping to reserve restore normal engine operation? You don’t cite the last one, but the other two eerily remind me of my latest performance issue. PITA is what that is.
Old Jul 22, 2020 | 10:35 PM
Bone78's Avatar
Bone78
5th Gear
No reserve position, quick splash of gas and your off like a prom dress.
Old Jun 5, 2022 | 02:18 PM
Bone78's Avatar
Bone78
5th Gear
Replacement filter didn't seam to last long
Old Jun 6, 2022 | 06:36 AM
The Twigster's Avatar
The Twigster
Same problem on my Dyna. Replaced the fuel pump. No more problem.
cam2zap
Mar 20, 2022 02:35 PM
cam2zap
Jun 22, 2019 11:35 AM
shortride
Feb 3, 2014 05:41 PM
snordman
Exhaust System Topics
Sep 15, 2009 04:18 PM
usmaleky
Jun 2, 2008 07:59 PM
