Help please
Old Aug 18, 2023 | 10:57 PM
Tatt2dlildude's Avatar
Tatt2dlildude
Stage II
Default Help please
Pulled into smoke shop and throttle cable got hung up wide open for at least 20 seconds and now my rear cylinder isn't functioning, I have spark, 96ci S&S with a thunderheart stand alone ignition module,single fire coil new plugs and wires, compression check within 2 #'s of each other and bleed down test good on both cylinders.
Old Aug 19, 2023 | 03:09 AM
Jackie Paper's Avatar
Jackie Paper
How do you know it's the rear?
PS..
Welcome, William.
Hope you two enjoy your ride here.
Only as a suggestion, create a signature
line for your
bike, year, model, and all the
code letters.
You can add that bike photo to the signature too.
And also as a suggestion, make your next new post over in the new member welcome area to say hello.
Old Aug 19, 2023 | 03:55 AM
Tatt2dlildude
Stage II
PS..
Welcome, William.
line for your
code letters.
I'm experienced enough to know when my scoot is 1 lunging it and which lung is or isn't breathing so ta speak.
Old Aug 19, 2023 | 06:25 AM
Jackie Paper
So you want me to try to diagnose your problem and are unwilling to help me understand how you know that? All that checking you have done sure indicates you obviously know what you are doing. So??OK. Sounds good to me.
PS. Never seen a 2 cylinder engine within 2lbs of each other . That bad boy is perfect. Assume it's firing on rear with a single fire system. You would think with good compression, intake is pulling in a charge.
Possible so rich or lean from carb it's missing on rear?
D-Bag
Engine Mechanical Topics
Jul 17, 2014 09:21 AM
marine_hm@hotmail.com
Sep 6, 2012 11:08 PM
D-Bag
Electrical/Lighting/Alarm
Nov 13, 2010 08:45 AM
D-Bag
Nov 12, 2010 10:30 AM
LUMPY100
Apr 5, 2008 06:09 PM
