Ignition Coil Ohm Reading
Old Dec 27, 2023 | 04:50 PM
Heritage666's Avatar
Heritage666
Default Ignition Coil Ohm Reading
Howdy all, question for all the gurus.
I’ve got a a stock 2007 FLHR and I’m testing the stock single fire ignition coil. I’ve got .5 on one pin and .9 on the other. I know it’s supposed to read between .5 and .7 but is this a tell tale sign of a faulty coil?
Thanks for the help in advance.
Old Dec 28, 2023 | 08:53 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Deleted..
Old Dec 28, 2023 | 09:04 AM
Rounders's Avatar
Rounders
What I can tell you is, I have had the ohm good, and fail periodically. Heat or vibration I don't know.
What is going on?
I am replacing my 07 this winter based on age, when I have tank off
Old Dec 28, 2023 | 10:34 AM
Heritage666
Thanks for the reply, been chasing an intermittent stutter at mid rpm’s for a while now. Hopefully this is the culprit. Ordered ignition, wires, and plugs. Fingers crossed!
Old Dec 28, 2023 | 10:51 AM
Rounders's Avatar
Rounders
It is a 17 year old bike,can't hurt.
Old Dec 29, 2023 | 10:41 PM
Max Headflow's Avatar
Max Headflow
Nope you probably measured across the wrong 2 pins to get the 0.9 ohms. A random miss ain't caused by a bad coil unless the motor is really erratic.
captaintag
Aug 14, 2021 07:35 AM
astark
EVO
Aug 2, 2013 12:29 AM
jfsgb
Shovelhead
May 10, 2012 11:59 AM
harleymark
Mar 4, 2009 08:32 PM
rlbfxe
Aug 25, 2008 06:36 PM
