Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
if i load it onto computer theres way too much to take a pic of. From what i see everything looks normal besides the iac steps. Temp looks consistent, and the bike performed pretty flawlessly 🤷🏻♂️ but iac did go to >100 and eventually hit 0. Didnt stall and revs never hung once. What the duck lol
in that case , ill leave it and watch it, cause if the IAC was hunting the revs would be also .
yup running ok besides needing throttle to keep it from dying when i start it. Just very peculiar why the IAC is not affecting anything when it goes from 0-100 and back to 0
its pretty random honestly. Ill do some more riding and keep an eye on it. When im using throttle it seems to be in range somewhat. Ots mostly when idling i believe
cleanup the throttle and iac with the mercury power tune cleaner. jus t spray it in while the bike is running and it will clean out everything.Have nothing to loose
Took intake off, went over wiring and changed out map sensor with one off the old intake. Iac steps were low but didnt hunt. Turned out throttle blade screw and lowest its been is 16 so far. Idles a bit more consistently too 🤞🏻🤞🏻
making progress. I think the steps depending the idle speed set is around 20-30 when warm
