Smart Tune Pro clarification
Old Jun 3, 2024 | 09:29 PM
Leimy's Avatar
Leimy
As in many other threaads about a bolt-on tuner VS dyno tune.
Consider the costs. What ever "magic" happens with tuners and the auto adjusting of the ECM ( yes folks, the modern ECM have the ability to adjust automatically), if you get some increase, it's good.
A dyno tune is better. $550-$750+
A dyno tune is STATIC. It adjusts for that day: air, temp, humidity, elevation and even quality of gas. Once you have a change in elevation, temp, humidity, the TUNE is not perfect.
The ECM and any auto adjusting tuners allows for these changes to occur.
Good Day~
Old Jun 3, 2024 | 09:45 PM
paulmedford's Avatar
paulmedford
Originally Posted by FatBob2018
That's basically what I was expecting, except the notion that it can only learn in the Closed Loop area.
I expected that the only way that the ECM gets changed is if you do a Smart Tune or Auto Tune session on your tuner, recording data, then merging the maps and re-writing to the ECM. Since the tuner is the only device that actually communicates with the ECM, that surely had to be the only way to refine the tune closer to optimal, without having to start over from scratch.
But surely that recording session applies to the Open Loop area as well? When you're running a Target Tune-enabled or Smart Tune-enabled calibration?
From what was said here it looks like the in a " auto tune" the log is recording the correction needed via the Wideband, of which you would have to program or write to the ecm these estimated correction values so you get a better tune. The closed loop uses narrow band, and is designed for the ecm to update the correction factors itself. ( I know in cars it does this). Theoretically, if the ecm could use the Wideband to update itself, we wont need tuners again lol. Maybe soon it wi]ould be so, or maybe its there already as suggested.
Old Jun 4, 2024 | 05:24 AM
Slingshot383's Avatar
Slingshot383
Paulmedford - You would still need Tuners to adjust timing values, O2 sensors deal with fuel clipping only, so they don't tell the whole story.
Old Jun 4, 2024 | 06:38 AM
paulmedford
very good point, only way to do that, is to look for knock and minus timing, but , still not optimum, of have built in cylinder pressure monitors in the future to optimize ignition timing.
Old Jun 4, 2024 | 10:41 AM
TwiZted Biker's Avatar
TwiZted Biker
Let me pose a quick question, I have a chance to pick up a stock M8 headpipe and the complete SE smart tune system for $80 off a wreck getting parted out.17 Road King has the black SE tuner already and doing a mild cam later. Worth my time & effort for one that isn't getting run hard ?
Old Jun 4, 2024 | 11:14 AM
FatBob2018's Avatar
FatBob2018
If you're asking me, I'd grab it. If you're installing it on a bike that already has a stock headpipe, you'd be way money ahead, especially if it has a tuner already. I do think it's a good product, just marketed over the top. Make sure you get the O2 sensors as well, and the front cylinder extension cable if it has one.
AKL1
Jan 19, 2020 03:03 PM
Lwood10
Jul 10, 2019 02:54 PM
Mattbastard
Oct 11, 2017 10:08 AM
jambo1989
Oct 29, 2016 04:13 PM
Rickm
Jul 24, 2012 08:11 AM
