Help with Codes
Old Nov 6, 2024 | 06:47 AM
NTrider's Avatar
NTrider
Default Help with Codes
07 Night Train:
Three codes are showing and I need advice on how to tackle each one.
P 107 = map sensor open/low
PO 502 = VSS Sensor high/open
PO 505 = idle speed control unstable
Old Nov 6, 2024 | 06:32 PM
marcodarq's Avatar
marcodarq
buy the electrical diagnostic manual and it will give you all the info you need to properly diagnose and repair the causes of your faults. first thing to have when doing the job.
m
Old Nov 6, 2024 | 09:43 PM
FLTRI17's Avatar
FLTRI17
Originally Posted by NTrider
07 Night Train:
Just an experienced guess.
Chances are slim-to-none all those codes are legit. Bike runs fine right?
First question…do you have a Power Commander on the bike?
When and what was the last thing done to the bike? Any electrical work? Connector not all the way clicked together?
Let us know,
Bob
Old Nov 7, 2024 | 05:26 AM
NTrider's Avatar
NTrider
Thank you for both of your responses. The sensor coming out of the transmission had the wires previously spliced and switched. Once that was corrected the bike is not showing any codes and seems to be running a lot smoother.
Old Nov 7, 2024 | 12:03 PM
FLTRI17's Avatar
FLTRI17
If you are referring to the neutral switch on top of then tranny, Not sure that could
have anything to do with the codes you listed OR run quality.
And it makes no difference how that sensor is wired because it is just a make-or-break switch.
Good luck
Bob
Old Nov 7, 2024 | 12:58 PM
NTrider's Avatar
NTrider
Not talking about the neutral switch. Rather the VSS.
batman.
2014-2024 Touring Models
May 17, 2019 08:46 PM
BanditCVMA
Apr 24, 2017 09:04 AM
alan911
Jan 6, 2014 10:39 AM
RSDickson
Apr 29, 2013 06:31 AM
virginiajoe
Jan 3, 2011 07:12 PM
