spark
Old Jan 6, 2025 | 09:32 AM
4skinhead's Avatar
4skinhead
Stage III
Default spark
I have a 2005 dyna fuel injection, running perfectly before stripped for exhaust bolt snapped,the tank is off being sprayed,my question is I have no spark when cranking,does it need fuel pressure to have a spark,as the bike was fine before stripping.
Old Jan 6, 2025 | 10:47 AM
470004's Avatar
470004
Welcome to the forum from New York.
Old Jan 6, 2025 | 11:42 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Welcome to the HDFORUM. A Community Team imoo6170 will probably move your thread to proper area. Just a suggestion but come back here to say hello with a new thread.
Are the plugs in? It needs compression. Also, the speedometer is unhooked, so that is probably the issue. It has communication with ECM, signal light/or alarm signal light box.
Old Jan 6, 2025 | 12:01 PM
r-bar-j's Avatar
r-bar-j
Welcome from Alamo City, SanAntonio, TX.
Old Jan 6, 2025 | 12:16 PM
squirrelsnest's Avatar
squirrelsnest
Welcome to the forum from Virginia.................
Old Jan 6, 2025 | 12:58 PM
imoo6170's Avatar
imoo6170
@4skinhead I have moved this thread from the Welcome section to the Ignition/Tuner/ECM/Fuel Injection section as you will get better responses to your question in this section.
The Welcome section is more for introducing yourself & letting other forum members know what Harley Davidson you own. Please feel free to post a new thread back in the Welcome area to introduce yourself.
Old Jan 8, 2025 | 03:03 PM
4skinhead's Avatar
4skinhead
Stage III
that makes sense,ill wait till tank is back on.
Old Jan 8, 2025 | 07:15 PM
Ed Ramberger's Avatar
Ed Ramberger
It does not need fuel but it needs compression. If you are cranking without spark plugs installed it will not spark.
Old Jan 8, 2025 | 09:28 PM
Rounders's Avatar
Rounders
I am just curious why you are cranking on it.
Old Jan 12, 2025 | 09:32 AM
Rocking_it's Avatar
Rocking_it
Curiosity killed the cat” is a proverb that warns against being too curious or investigating something that doesn't concern you.
