Fuel Pump problems
Old Mar 11, 2025 | 08:27 AM
Jammerou812's Avatar
Jammerou812
Stage I
Angry Fuel Pump problems
I have a 2008 Dyna SuperGlide. Bike ran fine 2 summers ago, I garaged it Winter 2023. when i went to bring it out last year the fuel pump wouldnt prime or turn on. I couldnt remember if I added the fuel stabilizer for winterizing, so I ordered new pump and put it in. It still will not power on or prime. I've checked all the fuses and veerified good. I went and bought new relays still no go. So now I am down to tracing wires and checking the run switch. Then a buddy said his V-Rod did the same thing and it turned out to be his ThunderMax auto tuner. I downloaded the logs and sent them to Thundermax and they said everything looked fine from the logs ... I've never had any issues with it, and cannot find the old HD ECM to swap it back out. Theres a change its gone for good after I moved after Divorce back in 09. So can't I just flash the map or update or replace firmware to resolve issue on the Thundermax? If not does anyone have a used Thundermax for Dyna for 2008 era for sale? Open to any other troubleshooting steps, I have already read a thread on here from back in the day and tried all those steps too.
Old Mar 11, 2025 | 11:33 AM
nevil's Avatar
nevil
Are you getting 12V to the fuel pump?
I doubt it's a problem with the TMax ecm.
Old Mar 15, 2025 | 11:47 AM
roussfam's Avatar
roussfam
So you changed the pump, changed the relays and now you want to change the Thundermax? It's your money but any Dealers or Indy's nearby?
Old Mar 15, 2025 | 11:58 AM
nevil's Avatar
nevil
Still waiting to see if you checked that you're getting 12V to the pump. Diagnosing parts is better than just buying new ones that you suspect.
Old Mar 18, 2025 | 10:08 AM
roussfam's Avatar
roussfam
One and done
motosynthesis
Jun 23, 2023 03:26 PM
LunchBreak35
16
Oct 14, 2017 07:35 PM
Ottar Kaasen
Apr 24, 2016 06:25 AM
dnshat
16
Sep 20, 2014 04:56 AM
HarleyMast
Dec 6, 2010 01:42 PM
