Diagnostic Tool
Old Oct 28, 2025 | 12:14 PM
wadejesu's Avatar
wadejesu
Default Diagnostic Tool
This solves everything
Harley diagnostic tool FXTUL M4 multi-system OBD2 scan fault
Old Oct 29, 2025 | 08:02 AM
bustert's Avatar
bustert
having the tool solves one part of the equation, understanding the hierarchy is next especially when you have several codes since a fault can throw codes in a round about way not related. then there is the code that can have multiple ways to get thrown and you need to find out which was which.
have fun
Old Oct 29, 2025 | 10:16 AM
wadejesu's Avatar
wadejesu
What do you do if you have a fault warning but no codes?
Old Oct 29, 2025 | 02:07 PM
Max Headflow's Avatar
Max Headflow
FWIW IIRC It depends on the model year.. Not sure when but early EFI / Ignitions will require a diagnostic tool to get historic codes but the later stuff will show historic codes. They put an "h" or "c" after the code.
Old Oct 29, 2025 | 02:17 PM
Mongo1958's Avatar
Mongo1958
Interesting. I wonder if the "Y" connector, with the 4/6 pin connectors, could be used on my OBD2 reader that I use for the truck and car?
Old Oct 29, 2025 | 04:40 PM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
It’s a decent price, I paid $100 for my HF automotive one just to clear a code after I installed a evap purge valve.
that was well worth not going to a dealer though
Old Oct 30, 2025 | 05:14 AM
jake24lt's Avatar
jake24lt
I find it odd that it doesn't give what years of bikes it works with. Also, bleeding abs brakes is a series of timed pump activation s and bleeding sequences, for those who haven't done it. Not sure how that would work, given all the different technologies currently. Also, tech support is in china. Good luck with that.
Get in Touch
Bao’an Industrial Park, Shenzhen, Guangdong, China
Call: +86 13828353522
support@autotul.com
Old Oct 30, 2025 | 08:31 AM
bustert's Avatar
bustert
in days of olden, you needed a driver to work the abs but those are gone and systems are bleed through and do not require you to pulse the solenoids, even then you can do that with a very cheap logic pulse tool.
with the right communication protocol and a home made test harness you can use just about any scan tool. in the beginning, i had an OTC unit, very expensive back then (1500) and you needed variety of connectors (and modules) since OBD was not around and the tool included a loose end test harness to tap into system that did not even have a port.
Old Oct 30, 2025 | 09:00 AM
memphisharley's Avatar
memphisharley
Get in Touch
support@autotul.com
it says "early 2000 up"
Old Oct 30, 2025 | 10:09 AM
Max Headflow
I would suspect that it might not do the MM efi..
