Fuel Tank Check Valve O ring leak
Old Mar 21, 2026 | 11:02 AM
jim70's Avatar
jim70
Default Fuel Tank Check Valve O ring leak
Hi all,
My 2006 RoadGlide has a leak at check valve on lower left side of tank. EFI system.
I read about the 2 o rings and procedural instructions and tooling to remove and replace the o rings. Not sure which ring but perhaps the lower one I hear quite common?
My question,… is it possible to simple remove the disconnect check valve from bottom of tank and replace it without tank entry?
I see that slinky hose attached to valve and is that machine pressed on or can it be pulled off and refitted to another check valve?
Looking to see what best easy way to do this task.
Your recommendations and expertise appreciated.
Thanks to all.
Jim
Old Mar 21, 2026 | 09:02 PM
marcodarq's Avatar
marcodarq
The short version, no.
you have to go in. Not hard, get the manual and quality replacement parts and itbwill be ok.
m
Old Mar 23, 2026 | 03:29 PM
hardheaded's Avatar
hardheaded
Not worth all the BS. Buy the Fuel Tool and o-rings and be done with it
Will last many more years.
Old Mar 23, 2026 | 06:38 PM
Schex's Avatar
Schex
It’s usually just one oring, I’ve replaced numerous orings with a pick and mirror, drain plug o-ring works.
Old Mar 23, 2026 | 08:27 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
If you don't pull the fuse to the fuel pump and relieve the pressure or let it set a day, if you remove the quick release, it will knock the upper ring around and it will leak when you put connector on.
Take a smooth rounded 90 degree pick and pull the two rings out. Get the replacement rings from Harley or J&P Cycle.
You really don't need a install tool. If you did it for a living, maybe so.
Old Mar 24, 2026 | 12:07 AM
marcodarq's Avatar
marcodarq
For what its worth, i DO do it for a living. The fuel tool is not always as easy as people believe or spout off about. The orings have a short term 50/50 failure rate as well, the ones that come with the tool. Better off just replacing the check valve for a more reliable repair.
m
Sportster1689
Jan 28, 2025 03:58 PM
CrimSonami
Jun 4, 2021 08:45 AM
Jag Jim
EVO
47
Jul 8, 2018 06:16 PM
beemer737
Exhaust System Topics
Aug 25, 2010 05:53 PM
bigstevex4
Jul 25, 2008 10:06 PM
