Head spinning...help stop
My local Dyno shop (small ma & pa place), strongly recommends that I purchase a ThunderMax w/AutoTune for my bike. The thing is I am having a really hard time dropping the $800 + $200 Dyno fee just for this system. I spent a few minutes with Jason from Speed's Performance at the last big rally out here talking to him about the ThunderMax and Power Commander systems and I am puzzled between the two.
Speed's Performance will sell me the Power Commander, install, and fully tune the bike for $599, not a bad deal. Now when I talked to Jason about the Thunder Max system he was saying a lot of places will stick with the Power Commander because so many more shops know the system and can easily tune the bike with it then a ThunderMax. I want to be able to tune the bike myself once I start to get a good feel for this stuff and Jason said the ThunderMax is not a very user friendly device like the Power Commander.
My local Dyno shop is really pushing the ThunderMax for one reason over the Power Commander and that is because it will not eliminate the O2 sensors on the bike. The tech guy there says "Harley put them there for a reason, why would you eliminate them?" The biggest selling point the Thundermax really has is just the AutoTune capability. With these guys being a small shop, they seem to have a pretty good knowledge of things, but how will I know what they are tuning on my bike is suffcient when a place like Speed's Performance doesn't even mess with the system?
I just feel like I am being "sold" a product like the ThunderMax at my local place, but I needed some guideance from others whether I am being sold or not. What are the drawbacks of the Power Commander eliminating my O2 sensors? If the bike is tuned with either system what is the advantage of an AutoTune option then?
Right now I just have Screamin Eagle Slip-Ons installed, but I plan to add a cam and intake over the winter...eventualy I would like to think about a big bore upgrade too, but would the Power Commander still give me the flexibility in tuning my engine or not?
I apologize that this is such a well covered and discussed topic, I just always seems to find, what I feel, biased information on one or the other....especially when I talk to local shops.
Where as the Thundermax actually "tunes" to the air and how your bike runs. You dont NEED to dyno it but if you want every last HP out of it then by all means go hard.
Also I believe the Powercommander does nothing more than modify injector pulse times.... Pretty archaic.... where the Thundermax adjust based off of AF ratio AND THE IGNITION TIMING CAN BE ADJUSTED. Which is worth the price by itself.
600 bucks for a fuel dump computer...
\or 800 for a fuel / air real time adjustment AND ignition timing? Totally worth it...
VicW.
I appreciate the help also fellas!
At this time there are the PC, Tmax and DTT. I have the DTT mostly for the larger range of adjustability. I know a few to have the Tmax and are very happy. Dont waste your money with the dyno tune. Put the Tmax or DTT in and ride it.... You will tell the difference and be happy. Ride for a bit and self tune (play) to get any pinging if any out then ride some more. THEN when you are happy with it do get a dyno run and see what the baby is doing then tweek it from there. Putting it in and then dyno running is a waste of money. These systems need TIME period to adjust. The Tmax needs to be run and turned on and off to set the adjustments it is recommending so dyno runs are a waiste upon initial install.....
I hope I confused you more but it is some solid advise....
IMO with what some of these systems cost that's not much of a solution... [sm=ummmmokay.gif]
2) Just for the $hits & grins, look at V&H's website here: http://www.fuelpakfi.com/harley1.html
and see if they have a Fuel Pak map for the configuration you want to run. It's an easy lookup, and if they do it's a lot cheaper (<$200 new and no dyno time) to get your air-fuel ratio right. It lacks the sophisticated tuneability of some of the more elaborate systems, but it is changeable as your pipe/ECM/filter/cam configurations change and it also lacks the premium price tag.
Ain't sayin' it's better or worse than any of the other systems- it's just another option...
If someone is trying to sell you a T-Max and a dyno tune, they dont know the system very well, no need to dyno unless you really want to know final numbers after the system has been on the bike for a while.
And do check with Shooter64 for the best prices on either unit. Self install is not difficult, just takes a bit of time.
