Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
2001 softail,,crane fireball hi-4,,,,melted! also blowing head light bulb. Any ideas where to start? Bike started blowing head light bulbs, then on a ride, engine poped a time or two and would not re-start, ing module was melted! Replace it with a second one to try and start, bike started- check voltage at battery, 12.8, then as reved bike, voltage went down to 7.5-8v, then the ing module started smoking,,,and ideas or where to start??
Yeah, with a thorough diagnostic session on the charging system. Get the manual and follow the instructions with a multi meter. Charge up the battery first. What's the no-load output of the stator? What's the voltage regulator output at idle, at 3K RPM?
