help with diagnostic codes please
Old Oct 17, 2007 | 06:12 AM
Chips's Avatar
Chips
Default help with diagnostic codes please
I have a '05 1200C
When my engine light came on I did a diagnostic check and got the following information...
P - System Voltage High - Priority 22
SP - Accessory line overvoltage - Priority 7
- Ignition line overvoltage - Priority 6
How serious is this? What should I do?
I would appreciate any comments / advice
Old Oct 17, 2007 | 07:28 AM
Doc 1's Avatar
Doc 1
Default RE: help with diagnostic codes please
Sounds as if the regulator is going out....check the voltage at the battery while it's at a high idle (say 2000 rpm) running, it should be about 13.5 to 14.5. If it's over this voltage install a new regulator.
Old Oct 17, 2007 | 01:28 PM
Wags1's Avatar
Wags1
Would have to agree with Doc1. Those over voltages and high voltage indications would point to your regulator. Luckily it is easy to get at and replace.
Old Oct 18, 2007 | 06:05 AM
Chips's Avatar
Chips
thanks for the reply....i'll call the service dept. today and have it looked at.
thanks again,
kevjo
Sep 10, 2018 06:51 PM
Michael Gamboa
Electrical/Lighting/Alarm
Apr 25, 2014 06:58 AM
flagshipjoe
Nov 24, 2011 01:09 PM
trackadaptor
Oct 16, 2011 10:24 AM
Chips
Oct 16, 2007 06:46 PM
