Terminal Velocity vs. Thundermax Closed loop
Ultra 61:
Just curious why are you bumping all these threads with the TVII in it back to the top?
Honestly to answer your question I was just trying to get out of this thread and every time I did somebody else came back knocking the TVII. There's quit a library up here already of post discussing the TVII with many an owner responding positive. I realize it is not for everyone. For those who seek to squeeze the most out of what they have, I wouldn't recommend it.It's a simple unit that only requires installation. My goal was simply to have a Bike that runs good, and I didn't have to tinker with it anymore. When I say run good, my definition is a smooth running, reasonably powered motor that gets decent mileage. I'm not looking for a stump puller.
I did the SERT on my last ride an 07 Wide Glide. They squeezed every last pony out of her. My fuel mileage was in the 30's. Living in the Phoenix area, the weather here is quite extreme. You can have mornings when it is 40 degrees and afternoons in the 70's. Not to mention the summer months when it never dips below 100. This was a major part of my decision. I wanted a unit that could adjust for cold weather one minute, and hot weather the next. Anyone who has ever had a carbureted bike knows that one extreme requires the bike be richer, and the other leaner. You can also go from no altitude, to over 6,000 feet in an hour. Once again I wanted a unit that would adjust.
Thats what directed my decison. That and I didn't want a unit that I had to mess with. For my simple needs the TVII filled the bill.
So to review...I wanted the TVII seemed simple to me...I already had the SERT, did not like the dyno runs at the dealer (harsh on the engine)...got convincedby all the responses of the post that I re-bumped back up that maybe just maybe the TMAX is more I wanted for 268.00 dollars more...after furtherdebatethe decision was made by me...the bike runsgreat...not hard to install...my speedo is now accuarte...fuel mileage is great...and I can look how my engine is running ifI chose to (I have not yet)...because I just plugged it in and it played...sweet.
It is not my goal to tell people or even argue a point that I made the best choice because I may not have...you on theother hand say you do not knock other similar products but you do and you have convinced yourself that this is as far as you need to go w/ your engine, and it may not...perdicting the future is not my fortay...but obviously is yours...I have been riding and messing w/ bike enginesfor 40 years, I don't expect that will change any time soon...since I am only 46...it is a "been there done that" thing...and I believe most of the debates you are having over this issue is w/ guys who "have been there and done that",otherwise their passion would not be so great...they just may have another goal than you and I...There end may very well justify their means...IMO...02 cents
Now this is communicating. I have learned more from your one post than all the others up here. Up till now I never heard of the eight page manual. After reading post after post of these guys complaining about fuel mileage and tweaking the rear cylinder 2 degrees on timing, and messing with the AFR table I was asking myself one big question. How the heck can they call this thing auto tune?
But what you have just said is exactly what I have been looking for. A bolt on unit, that you simply installed and it ran great, and has improved over time. You didn't have to read the Bible of tuning, and yours autotuned itself. Now if I saw more threads like this I might be tempted to buy it. I don't want to have to mess with the bike. Like you said, I just want to bolt it on and see a positive change in the motor and the more I ride it the better it gets. When you say good fuel mileage, just exactly how good?
Sometimes a simple answer is the answer.
Thanks
~2 up 39-40 Trips
~Just me 39-45
07 Ultra
TD V&H 1.75 Rush
TMAX
I love to turn the throttle...
Ultra61 can you point me to that 8 page manual is it in pdf format somewhere. I went the TMax site but can not find the manual - thanks!!
http://www.thunder-max.com/Support/I...on%20V2007.pdf
and here..
http://www.thunder-max.com/Support/I...g%20Manual.pdf
Enjoy
