Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Installed TMAX a few days ago and everything works fine (SWEET). I have only one issue, engine light comes on between 60 & 70 mph and will go off between 30 & 40 mph. Bike runs good with light on. XL1200Low Sportster.... Anyone have this problem before or any ideas?
Link to the Tmax and check your temperature logs. If you see logs in temperature above 300 then that was the high temp alarm. On v4.4 firmware it's set too low for the Sportsters. On v4.5 it is set at 350...and customizable....much better for our Sportsters.....
My Sportster runs about 300-325 most of the time....
