check engine light
Old Mar 5, 2008 | 04:42 PM
questor's Avatar
questor
Default check engine light
Today while cruising in 6th gear around 75mph, my check engine light came on. Down shifting to 5th, the light went out. Shifted back to 6th and about 20 miles later the light came on. Down shifting again, the light went out. Back into 6th and 40 miles later I arrived at home without the light coming back on.
Checked the oil level before & after ride and still at full mark.
Any ideas?
Old Mar 5, 2008 | 04:54 PM
dawg's Avatar
dawg
Default RE: check engine light
I'd start by checking the historical codes through the speedo and see if you have any. Then go from there.
Old Mar 5, 2008 | 05:12 PM
rjmac53's Avatar
rjmac53
It's an error code. You can check it as dawg said or your dealer will do it for you.
Old Mar 5, 2008 | 07:48 PM
questor's Avatar
questor
ORIGINAL: dawg
didn't know about the "historical codes". On my way to garage to getowners manual and
search for procedure to read the codes.
Thanks..
Old Mar 5, 2008 | 08:00 PM
dawg's Avatar
dawg
ORIGINAL: questor
Thanks..
won't be in owners manual, need EDM or go HERE. Same procedure on the 07
Old Mar 5, 2008 | 08:20 PM
questor's Avatar
questor
ORIGINAL: dawg
Just found that out and then went to 2007 Service Manual for "Check Engine Lamp Illuminates During Operation" their solution: Fault detected. Check for trouble codes.
Might have missed it, but didn't locate anythingin Service Manual for "trouble codes".
Thanks for the link, will print out tomorrow when I get ink for printer.
Again thanks for link and info...
Old Mar 6, 2008 | 04:59 AM
questor's Avatar
questor
ORIGINAL: dawg
Code is P1653 and it isn't documented in the link you provided.
Checked it three times and same code P1653. Will call dealer later this morning..
Old Mar 6, 2008 | 05:17 AM
dawg's Avatar
dawg
Just post here and ask what P1653 is. You can still clear the code. I don't have 2007 EDM info on hand otherwise I could tell you.
Old Mar 6, 2008 | 05:18 AM
Big Peter's Avatar
Big Peter
ORIGINAL: questor
ORIGINAL: dawg
Hey questor,
I found this
P1653:
Flash Code 35
Tachometer Output Low
So nothing to worrie about
Peter (Netherlands)
Old Mar 6, 2008 | 07:00 PM
questor's Avatar
questor
ORIGINAL: Big Peter
P1653:
Flash Code 35
Peter (Netherlands)
dang you are good. Visited local shop (Eastern Performance) this am and they couldn't find it, called Annapolis HD. Service desk said, can't locate the diag message, will call you back. That was 1000 EST and still haven't heard back.
bigPeter what manual did you locate the code in?
