check engine light
Old Mar 7, 2008 | 03:14 AM
Big Peter's Avatar
Big Peter
Default RE: check engine light
ORIGINAL: questor
ORIGINAL: Big Peter
P1653:
Flash Code 35
Tachometer Output Low
So nothing to worrie about
Peter (Netherlands)
dang you are good. Visited local shop (Eastern Performance) this am and they couldn't find it, called Annapolis HD. Service desk said, can't locate the diag message, will call you back. That was 1000 EST and still haven't heard back.
bigPeter what manual did you locate the code in?
Hi questor, you're welcome
No manual, found it on the internet.
Went to Google and typed: p1653 harley
Let me know the outcome.
Peter (Netherlands)
'99 RKC
S&S .510G gear drive cams
PC111 powercommander
SE pro performance pipes
AN Big Sucker aircleaner
Corbin dual tour saddle
Old Mar 7, 2008 | 03:22 AM
Big Peter's Avatar
Big Peter
ORIGINAL: Big Peter
ORIGINAL: questor
ORIGINAL: Big Peter
P1653:
Flash Code 35
Peter (Netherlands)
Peter (Netherlands)
'99 RKC
questor, tell your stealer to check
the SE race tuner manual for the diagnostic code
Keep me posted.
Greetz,
Peter
Old Mar 7, 2008 | 03:27 AM
Big Peter's Avatar
Big Peter
questor,
Here you go [sm=biker.gif]
list of DTC codes from the SE Race Tuner manual. Sorry but this is from an 04 era SERT so you may get someone with a later version to get a listing of the later codes.
I found them in the help section of the Data Mode. Its specific name is the "Data Mode On-Line Help" section.
KT
DTC Descriptions
The following is a Diagnostic Trouble Code (DTC) quick reference. For complete troubleshooting information refer to the appropriate Harley-Davidson factory service manual.
Note: Not all the codes described below are supported by every vehicle.
P0107:
Flash Code 12
MAP sensor Low/Open
P0108:
Flash Code 12
MAP sensor High
P0112:
Flash Code 15
Intake Air Temperature Sensor (IAT) Voltage Low
P0113:
Flash Code 15
Intake Air Temperature Sensor (IAT) Voltage High
P0117:
Flash Code 14
Engine Air Temperature Sensor (ECT) Voltage Low
P0118:
Flash Code 14
Engine Air Temperature Sensor (ECT) Voltage High
P0122:
Flash Code 11
Throttle Position Sensor (TPS) Voltage Low
P0123:
Flash Code 11
Throttle Position Sensor (TPS) Voltage High
P0131:
Flash Code ??
Front O2 Sensor Low
P0132:
Flash Code ??
Front O2 Sensor High
P0134:
Flash Code ??
Front O2 Sensor Open
P0137:
Flash Code ??
Rear O2 Sensor Low
P0138:
Flash Code ??
Rear O2 Sensor High
P0140:
Flash Code ??
Rear O2 Sensor Open
P0151:
Flash Code ??
Rear O2 Sensor Low
P0152:
Flash Code ??
Rear O2 Sensor High
P0154:
Flash Code ??
Rear O2 Sensor Open
P0261:
Flash Code 23
Front Injector Low or Open
P0262:
Flash Code 23
Front Injector High or Shorted
P0263:
Flash Code 32
Rear Injector Low or Open
P0264:
Flash Code 32
Rear Injector High or Shorted
P0373:
Flash Code 41
Engine Position Sensor (CSS) Intermittent
P0374:
Flash Code 41
Engine Position Sensor (CSS) Cannot Synchronize
P0444:
Flash Code 31
Purge Solenoid (CCP) Low or Open
P0445:
Flash Code 31
Purge Solenoid (CCP) High or Shorted
P0501:
Flash Code 43
Vehicle Speed Sensor (VSS) Shorted Low
P0502:
Flash Code 43
Vehicle Speed Sensor (VSS) Open or Shorted High
P0505:
Flash Code N/A
Loss of Idle Speed Control
P0562:
Flash Code 16
System Voltage Low
P0563:
Flash Code 16
System Voltage High
P0603:
Flash Code 54
EEPROM Memory Error
P0605:
Flash Code 53
FLASH Memory Error
P1001:
Flash Code 33
System Relay Coil Low or Open
P1002:
Flash Code 33
System Relay Coil High or Shorted
P1003:
Flash Code 33
System Relay Contacts Failed Open
P1004:
Flash Code 33
System Relay Contacts Failed Closed
P1005:
Flash Code 44
Bank Angle Input Low
P1006:
Flash Code 44
Bank Angle Input High
P1009:
Flash Code 99
Incorrect VTD Password
P1010:
Flash Code 99
Missing VTD Password
P1107:
Flash Code 12
MAP Sensor Drift Low
P1351:
Flash Code 24
Front Ignition Coil Open or Low
P1352:
Flash Code 24
Front Ignition Coil High
P1353:
Flash Code 24
Front Ignition Coil No Combustion
P1354:
Flash Code 25
Rear Ignition Coil Open or Low
P1355:
Flash Code 25
Rear Ignition Coil High
P1356:
Flash Code 25
Rear Ignition Coil No Combustion
P1357:
Flash Code 24
Front Ignition Coil Secondary Intermittent
P1358:
Flash Code 25
Rear Ignition Coil Secondary Intermittent
P1481:
Flash Code 36
Fan Output Circuit Low or Open
P1482:
Flash Code 36
Fan Output Circuit High
P1651:
Flash Code 99
Check Engine Light Output Low or Open
P1652:
Flash Code 99
Check Engine Light Output High
P1653:
Flash Code 35
Old Mar 8, 2008 | 08:54 AM
questor's Avatar
questor
Peter
Thanks for the codes, I cut and pasted them into an email for the local HD service manager. As espected he hasn't replied.
The internet is a great tool, post my question and receive the reply from the Netherlands. Too far to swim and shake your hand, therefore accept my thanks.
Old Mar 8, 2008 | 11:51 AM
Big Peter's Avatar
Big Peter
ORIGINAL: questor
Peter
No matter where we live on this planet
Harley riders are here to help each other
You're very welcome.
Peter
fchalker1981
Jun 13, 2016 11:34 AM
Indpthwill
Nov 1, 2014 10:55 AM
G wizz
Jul 29, 2011 05:05 PM
tekeum
Jul 14, 2010 08:55 PM
Jordy806
Sep 9, 2008 08:07 AM
