Spark Plug Indexing
Old Dec 22, 2005 | 01:47 AM
twoseas's Avatar
twoseas
Default Spark Plug Indexing
I've read somewhere that indexing your plugs so the gap points towards the valves is mo better for combustion.
What do you do with a plug when tightened, ends up pointing 180 degrees out ??
Do you leave it slightly loose or crank down on it but being careful not to strip !
Thanks in advance.
Old Dec 22, 2005 | 10:25 AM
usblues101's Avatar
usblues101
Default RE: Spark Plug Indexing
Different thickness washers are used to line up ground electrode to face towards squish band.Its used so the charge isn't shrouded from the spark.Its also used for for more clearance between the piston dome and ground electrode.Mark your ceramic with a sharpie in line with the ground electrode and line it up facing squish band using said washers.The plug must ALWAYS be tightened correctly for proper heat transfer.This trick has not yet produced any scientific results I'm aware of,YMMV,Bob
Old Dec 22, 2005 | 10:39 AM
HDF Tech's Avatar
HDF Tech
Ray
Bob covered it pretty well, only thing I can add is that on a street bike that it is nothing that will even make a difference.
Here's some info on it in the DIY area ... https://www.hdforums.com/m_128195/tm.htm
jackietan
General Topics/Tech Tips
Dec 14, 2017 07:57 AM
cruzmisl
Jun 25, 2014 04:22 PM
jacknthebox
Apr 2, 2012 08:43 PM
nevil
Exhaust System Topics
Aug 2, 2008 11:04 AM
Shift_4lo
Mar 11, 2006 03:37 PM
