SERT Questions
Old Nov 24, 2007 | 07:30 PM
Superglide 04's Avatar
Superglide 04
Default SERT Questions
My cousin is selling his 07 Fatboy, he has sert installed and willing to give it to me. question is, is the sert only good on his bike or can it be installed on a different bike? question 2 what comes in the box I got the cd and the little module that plugs into the computer, is their anything on the bike I should be grabbing or is that all I need?
Old Nov 24, 2007 | 08:05 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Default RE: SERT Questions
The Screamin Eagle Race Tuner is not "installed" on any bike. It is a module used to transfer EFI tuning data to the bikes ECM. This data transfer reflashes the ECM with a new instruction set. The SERT cannot copy current programmed info from the ECM back to your computer. It will tell you the name of the calibration file currently loaded into the ECM, but nothing more about the file will be retrived. You can use the Data mode software to record "live" engine parameters. Dont confuse the SERT with a Power Commander type unit that must stay on the bike and works by fooling the ECM.
The SERT is NOT transferable to another bike. Once the SERT is setup and used on a particular bike, it will work only with that bike. To use the SERT, you will of course need the SERT module, the cable between the SERT and the computer, and the cable between the SERT and the bike. Starting-point calibration files are available on the CD, but these files were optimized for bikes using Screamin Eagle brand components. But generally, they are pretty good and in some cases can be used without further tuning...depending upon how much of a purest the owner of the bike might be.
Be sure and get a copy of the file that your buddy has loaded into the bikes ECM. You will need it if you ever need to reload it after screwing-up your bike messing around with tuning that may not go as planned. Read the SERT manual, twice. Then ask a lot of questions.IF you are not willing to go that route, you might consider leaving the tuning to someone else. Good luck.
Old Nov 25, 2007 | 09:39 AM
rjrivero's Avatar
rjrivero
ORIGINAL: Lowcountry Joe
I agree with Joe, but be sure to grab the cables if your cousin has them.
Old Nov 26, 2007 | 08:13 AM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: Superglide 04
I'm a bit confused - are YOU buying your cousin's Fatboy, or is he selling it to someone else and only giving you the SERT? If the latter is the case he should pass the SERT along to the new owner as the SERT is useless on any other bike.
Old Nov 26, 2007 | 10:54 AM
rjrivero's Avatar
rjrivero
ORIGINAL: Jim Dawson
Good catch. The SERT is only good on the bike to which it was mated. It should go to the new owner of the fatboy.
RJ
Old Nov 26, 2007 | 04:29 PM
Herr Monk's Avatar
Herr Monk
He could charge the owner extra for it though...
Micah
Jun 14, 2010 08:35 PM
Spanish Flyer
Jan 15, 2008 07:01 AM
Superglide 04
Nov 25, 2007 10:04 AM
sparky_mo
Jul 24, 2007 06:46 AM
rhinoevans
Nov 16, 2006 09:49 PM
