LED TAIL LIGHTS
Ifhowever, you are using them INSTEAD of stock turn signals, you'll need a load equilizer to mimic the load a standard light bulb setup draws on the system. My favorite is the one from Biketronics.
If you want to use them as RUNNING LIGHTS in addition to turn signals, and stop lights, then you'll need the newer module from HD Run/Stop/Turnsignal lights. You can splice into the harness after the module and your additional lights will have the same run/turn/stop function.
Good Luck.
RJ
Thanks for the in put, I an only going to use them for running and brake lights. The lens are red so i was only going to use the amber stock turn signal light. Thanks again
If you can live with the turn signal function on the outboard LED's then the best bet is to do this:
Using the HD run/stop/turn module, as described above, you want to splice the existing turn signals BEFORE the module, and then run the leads from the module back to the outboard lights.
Your turn signals will work as normal, and your outboard led's will be run/stop/turn.
Otherwise, you're looking at making a resistor/rectifier diode bridge to run the run/stop wires to the outboard leds.
RJ
http://s168.photobucket.com/albums/u.../LED%20Lights/
