Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Is there a contoller that allows the idle to be adjusted? My '06 fxdbi idles really high even after it warms up, which is extremely annoying.[:@] I haven't done pipes or air cleaner or anything yet.
Check IAC motor Steps at 250*...should read 40 to 60 steps, check Throttle position sensorvoltage, should read 3.5~4.5 at idle, check throttle plate to assure it is all the way closed. Make sure map sensor is not stuck.
Thanks, Doc! I'll check that stuff. I guess I'll need to pick up a service manual- I'm sure I'll need it sooner or later. Also, how low can you set the idle on an efi bike? A friend of mine has his (carbureted) softail set at around 600 (guessing) rpm, and it sounds bitchin'.[sm=badbadbad.gif]
