Correct VOES for Evo
Old Feb 5, 2008 | 03:01 PM
Fatboy931's Avatar
Fatboy931
Default Correct VOES for Evo
I could use a little help chosing a Voes for my 93 Fatboy. I bought the bike used. I've put17,000 on it and decided to pull it down and replace the head gaskets. Slight oil leak. Here iswhat I found.10:1 Wiseco pistons, Crane HI-4E, ported heads, Crane Fireball 316 cam, Mikuni HSR42, Thunderheader. The only change I am making is the cam and valve springs. The new one is a V-Thunder 244 at .053 with .585 lift. The Voes is the stock one and the bike would ping at lower rpm when rolling on the throttle. What vacuum setting VOES should I be using? Thanks.
Bill
Old Feb 5, 2008 | 04:41 PM
Doc 1's Avatar
Doc 1
Default RE: Correct VOES for Evo
5 3/4 ~ 6 this should be good for a bike with mods like you have
Old Feb 6, 2008 | 07:46 AM
Fatboy931's Avatar
Fatboy931
Thanks, Doc. I was guessing somewhere in that area.
machinehed
Jan 6, 2020 06:42 AM
Farm Shop
EVO
Jun 23, 2016 08:14 PM
doughnuts
Engine Mechanical Topics
Sep 23, 2014 05:59 AM
Fatboy931
EVO
Jan 28, 2008 07:48 AM
Blown 331
EVO
Nov 26, 2007 06:48 PM
