Heat Sensor
Old Jan 19, 2006 | 03:02 PM
Hooper's Avatar
Hooper
Default Heat Sensor
I am trying to figure out if a 97 Road King EFI has a heat sensor on each cylinder or if there is only one on the front cylinder. Had the bike scanned and it came back as a heat sensor. I know I need to replace it but if there are two, I want to replace both of them. Thanks alot guys.
Old Jan 19, 2006 | 04:40 PM
Hooper's Avatar
Hooper
Default RE: Heat Sensor
Old Jan 19, 2006 | 04:51 PM
HDF Tech's Avatar
HDF Tech
You should have only one on the front cylinder head.
Hooper's Avatar
Hooper
Is there one on the rear cylinder head?
Old Jan 19, 2006 | 05:34 PM
HDF Tech's Avatar
HDF Tech
Pssst..Jeff...You should have only one on the front cylinder head.
Old Jan 20, 2006 | 11:14 AM
Hooper's Avatar
Hooper
Sorry. I miss read your previous post. Thanks.
Old Jan 20, 2006 | 11:52 AM
HDF Tech's Avatar
HDF Tech
Jeff
Here's a chart with the values if you wanted to test it again before replacing it.
rgk
Aug 12, 2017 04:01 PM
linewatch
Engine Mechanical Topics
Dec 30, 2015 06:07 PM
stal94gt
Jul 3, 2015 11:42 AM
gdsbls
Nov 25, 2013 05:27 PM
Tltrump
Exhaust System Topics
Jan 30, 2008 01:17 PM
