SERT question(s)
Enlighten me please.
I thought you were running the tmax. Does it not perform?
Thanks for the reply.I was playing with the map last night very briefly and my observation between 2 maps of interest regarding my bike are my older map 159PZ004 and the newer map 179PZ005. It seems that the AFR was lowered in a certain kPA/RPM range in the newer map to 14.0 from 14.6 of the older map but yet both VE tables stayed the same regarding the 2 maps. I do understand that this must have taken the EFI out of closed loop during this time, but I was wondering why HD did this and if going to 14.0 was feasible, why not shoot for 13.8:1 throughout the cruise range overall? The timings are DRASTICALLY different between these 2 maps(RETARDED in the latest map),perhaps to combat PING, but yet the VE tables are mirror images of each other. I'd like an explanation for this please.
I understand the 2 concepts are different between the TMax and the SERT, but why can't you richen up the AFR to 13.8:1, gain a little power, cool the cylinders down a bit, by using the SERT and manipulating the AFR table alone?
1. what are the repercussions, besides a decrease in gas mileage, for taking the AFR down to 13.8:1 like in the map pic posted in the attachmentand changing nothing else within the map besides maxing the CLB tables in both Front and Rear cylinders to 798mV?
2. will thishave a secondary effectexhibited by an increasein performanceas well as cool the cylinders down some?
[IMG]local://upfiles/22226/4B64DD20F5864819B72EAFBA3CE60EDB.gif[/IMG]
[IMG]local://upfiles/22226/F64312713FB6419E818E9C9E14A11162.gif[/IMG]
In the mid range, you will not be taking advantage of the ECU ability to find 14.2 in thelow power areas of the map there the real advantage of the HarleyECU is at it's best. You will be totally at the mercy of your tuner to have theVE perfect (and he won't be that good) as the weather, fuel,fuel pressure and filter condition changes all the time. Any one of these can mess with theVE requirementsto hit the target AFR. This will also mess with your overall trim (I forgot the Harley name for it)
Hope this helps
AW
First, in your original question, you asked about a calibration with a 179 number. Did you mean 176?
If the answer to the first question is 'yes' then on to the observation. If the picture of your bike in your post is accurate, I can't see a 'Y' pipe on your rear cyl. If I'm correct and you changed your headers to duals, then the calibration your looking at may not be offering you the best baseline start point. I was told to look at #67 (176AE104) asa baseline. Even though you don't have 'shorties' you do have true dual pipes. Without the 'Y' a number of events and parameters have changed (like no scavenging, etc.). If you compare the rear cyl. numbers for the two cals mentioned, you'll notice big changes - most noticeable is that the numbers from front to back change very little with duals where there are more marked differences from front to back with stock headers with the 'Y'.
While we don't know how the shorties were baffled (regarding back pressure) in the MoCo example, we do know that the back pressure, flow rates, etc. are more, or closer toequal than with the stock 'Y' header.
Just my penny and a half.
Ok, what would happen if I took the AFR table on the map for my bike(179PZ005) and changed all the 14.6 numbers to 14.2 THEN maxed out the CLB tables to 798mV's? Would my overall AFR equate to something like 13.7-13.8:1 AFR? I'd leave the rest of the map alone and just change the aforementioned.
I've read this post several times hoping to understand what your attempting.............[sm=confused06.gif]
IMO, I would think changing all the 14.6 switching values to something different would automatically disable the Closed Loop operation; and hence render the CLB Tables useless. Again, If I'm remembering correctly,any cell value in the AFR Table that's not 14.6 will not operate in Closed Loop.
I would also think that any cells with 14.2 would only yield an AFR of that value if the VE Tables are right on the money.
Hope I'm not missing the boat here! [sm=interesting.gif]
Best Regards!
Ben
