SERT- BELKIN ?
Old Mar 17, 2008 | 07:02 AM
Hinzy's Avatar
Hinzy
Default SERT- BELKIN ?
To any and all who programmed your ecm,Did you change the baud transfer
rate for the belkin adapter or leave it at the default setting of 9600?
TIA
Hinzy
Old Mar 17, 2008 | 07:29 AM
FLSTF's Avatar
FLSTF
Default RE: SERT- BELKIN ?
Mine must be on the default setting. All I did was install with the cd that came with it and then programmed my ecu, worked first try.
Old Mar 17, 2008 | 07:58 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Give it a try. If it doesn't work Belkin has an upgrade for the software driver on their website.
Old Mar 17, 2008 | 02:11 PM
Hinzy's Avatar
Hinzy
Gents..
thanks for the responses,all went well with the programming.
I did change the baud rate to 128000 and all went well.
Although when I did the programming a dialogue box popped up
stated some thing to the effect that the grayed out area cannot be changed
on this model,I assume it has something to do with the international models.
the only other thing that showed up in the box was to enable or disable
the acr solenoid,I left it disabled.. right or wrong
wtf is the acr solenoid??
Thanks again
Hinzy
Old Mar 17, 2008 | 02:21 PM
Hinzy's Avatar
Hinzy
ORIGINAL: Hinzy
Gents..
Thanks again
Hinzy
sorry
found the acr answer in sert manual duuhhhh
Wheelup
Sep 8, 2010 06:39 PM
ButtMan1000
Oct 26, 2008 07:25 PM
joker1450
Mar 23, 2008 02:56 PM
Spanish Flyer
Jan 15, 2008 07:01 AM
Crazy Biker
Feb 20, 2007 12:31 PM
