'01 MAP Sensor
Old Mar 18, 2008 | 02:50 AM
onewayphil's Avatar
onewayphil
Default '01 MAP Sensor
Does anyone know if I can check my MAP sensor without a computer program? If I put the vacuum tool to the port on the sensor, can I check volts/ohms on the ABC pins, and if so which one am I looking for and what are the values?? I'm replacing the stock carb with an S&S and since I was having acceleration issues with the old carb I wanted to know for sure this sensor was OK. Thanks, onewayphil
Old Mar 18, 2008 | 07:31 AM
geargrinder's Avatar
geargrinder
Default RE: '01 MAP Sensor
Yes, A is Gnd, B is Signal, C is +5V. Use a volt meter and probe A to B, the voltage at B should lower from close to 5V to 0V depending on how much vacuum is applied with ignition and runswitch on.
Old Mar 18, 2008 | 11:35 AM
onewayphil's Avatar
onewayphil
Thanks geargrinder, I'll give it a shot...............oneway
edgeofinsanity
Mar 25, 2012 02:56 PM
primostoy
Apr 11, 2011 04:48 PM
rigglemg
Dec 16, 2010 10:55 AM
dennish
Dec 29, 2007 03:18 PM
128auto
Dec 19, 2006 11:18 PM
