pc111 idle
Old Apr 2, 2008 | 10:44 AM
shagnasty's Avatar
shagnasty
Default RE: pc111 idle
On the 06 model you do not have to have the bike running to set throttle position. Just turn ignition on.
Old Apr 5, 2008 | 08:45 PM
fathertime's Avatar
fathertime
From: CHILLIWACK B.C CANADA: have a u.s shipping adress
on mine it seems it HAS to be running..i tried many times w/o the bike running. ignition on ,run switch on,but still said device not communicating.. in desperation i fired it up and then everything worked fine..read 0 at idle and with a millisecond blip to full throttle the graph went red and seemed to reset fine.. in the pc111 instructions it says to watch the lights on the unit after turning ignition on, and if they go out after 5-10 seconds your bike is one that must be running to reset throttle position...in the environmental options it lists different ways to save map on exit...which on should be used? the "always"???
Old Apr 7, 2008 | 03:24 PM
trevd's Avatar
trevd
My understanding is that the slow start thing is common for PCIII with '06's.
There are a few threads on it. Here's one: https://www.hdforums.com/m_1273034/tm.htm
Electra1
13
Jul 9, 2008 08:30 AM
05 HD Deluxe
Apr 27, 2008 06:25 AM
forestfarm
Jun 4, 2007 11:43 PM
BadX
May 24, 2007 07:22 PM
nada1
Mar 12, 2007 09:17 PM
