tach hook up
Old Mar 30, 2008 | 04:42 PM
hdfatboy54's Avatar
hdfatboy54
Default tach hook up
Can you guys educate me on coils, I am looking to buy an aftermarket tach for a 2002 softail. Some of the manufactures are saying i will need a tach adapter for single fire coils. Is the coil on this bike considered a single fire coil. The parts book calls it a dual spark coil, so its a bit confusing. Bye the way this is a carb model.
Another question, other than higher revs. would there be any benifit in putting a screamin eagle ignition system on this bike.
Old Mar 30, 2008 | 08:55 PM
jmetro's Avatar
jmetro
Default RE: tach hook up
look at your coil, if it has 3 wires going into it other than your spark plug wires, it is a single fire. if it only has 2, its a dual fire system. follow the instructions for the correct setup.
Old Mar 31, 2008 | 06:50 AM
murphdog's Avatar
murphdog
Twin Cams have single fire ignition...3 wires to the coil. On a 2002, you should have a pink tach signal wire under the dash. This is where you would pick up the tach signal, not at the coil itself.
Old Mar 31, 2008 | 06:46 PM
hdfatboy54's Avatar
hdfatboy54
Thanks for the info. I did see that wire under the dash and thanks for verifing that, and the tip on the three wire single fire coil.
Old Apr 30, 2016 | 05:48 PM
Br2's Avatar
Br2
Stage III
Default 2002 fxdwg3
Does the pink wire under dash hold true for dynas fxdwg3 in particular?
DaltonHD
EVO
Dec 8, 2011 07:59 PM
dkfxr
EVO
Jul 1, 2011 01:03 PM
Mrrick
Shovelhead
Aug 24, 2009 12:26 PM
rotorwing70
Dec 29, 2006 03:55 AM
rotorwing70
Dec 28, 2006 08:02 PM
