different cyl temps
Old Apr 9, 2008 | 08:29 PM
theroadking's Avatar
theroadking
Default different cyl temps
So I was out testing my new map the other day thought that I would take my temp gun, the outside air was 50* took temp on front cyl (about 15 sec. After I shut the bike off) it was 256* 1" from the plug, took the temp on the rear cyl 1" from the plug it was 306* so that is 50* difference between the two, is that normal ? Will I be able to get them the same with a dyno?
Old Apr 9, 2008 | 09:48 PM
murphyslaw1978's Avatar
murphyslaw1978
Default RE: different cyl temps
From what I've read, those numbers are normal.
Old Apr 9, 2008 | 10:31 PM
Doc 1's Avatar
Doc 1
Rear cylinder will run 15% hotter that the front. With fuel injection you can control both cylinders separate so a good tuner can get it cooled down to about 15 degrees different.
Old Apr 9, 2008 | 10:42 PM
theroadking
Thanks for the reply guys,
So the next question is anyone know a good tuner in the Salt Lake City, Ut area ?
FinalShot
Jul 22, 2015 10:49 AM
FATslob
Sep 9, 2014 01:33 PM
robandlyn
Jun 13, 2011 10:38 AM
drspencer
Jun 1, 2011 07:27 PM
40 Knuck
Feb 28, 2008 11:53 AM
