Lights always on
Old Apr 19, 2008 | 11:44 PM
enshurst's Avatar
enshurst
1st Gear
Default Lights always on
Hello all,
I recently extended my switch wire for different bars. I ran in to a problem that now when I connect the battery the turn signals come one with out turning the ignition switch on. When I do turn the ignition switch on my tail light comes on full blast and dims when I engage the front brake.
Also, my high beam indicator on the console comes on when I connect the battery and when I turn the ignition switch on, it is lit when the lights or on low beam and goes out when I switch it to high beam.
So I redid the wires (took out the extensions) with still the same problem. Is something in my console or switches bad?
I am at a loss right now, I am sure I screwed something up.
Thanks for your help.
Old Apr 20, 2008 | 05:29 PM
MiniMe's Avatar
MiniMe
Default RE: Lights always on
It sounds like maybe something is grounding somewhere. Wish I had more advise for you. Did you run the wires thru the handlebars?
Old Apr 20, 2008 | 05:46 PM
enshurst's Avatar
enshurst
1st Gear
Thanks for the response. I have since taken them out of the handlebars and rechecked all the wires. They are all connect correctly. I alsoremoved the console and checked the wires there. With the console on or off the turn signals lights come on as soon as I connect the battery.
I am just dumb founded.
Old Apr 20, 2008 | 09:32 PM
rjrivero's Avatar
rjrivero
I believe you crossed your wires. I *think* the ones specifically for the right hand control: Grey and White with Black stripe are crossed.
Re Check them.
Old Apr 21, 2008 | 12:45 PM
user 8373900's Avatar
user 8373900
What year bike?
Unless you put a spacerin your front brake lever you may have broken the brake light switch upon re-assembly. Many have done, it it is easy to do.The brake lights will stay on if this switch gets broken.
Do you have the brake/turn converter so your turn sigs are brake lights too?
Mark
Old Apr 21, 2008 | 03:53 PM
enshurst's Avatar
enshurst
1st Gear
Okay, here we go..
First, thanks to everyone that gave me some pointers.
Second, I am an idiot.
I found my problem. I was not connecting my battery directly to the bike but was using a “jumper” if you will. I attached a picture.
Apparently this not was not letting enough juice through, and caused my weird problems.
On the plus side, I am a master at soldering and pulling wires in and out of the handlebars.
Thanks again.
eglide_rider
Jan 2, 2017 11:26 AM
jimbo285
EVO
Apr 3, 2013 06:18 PM
redwing67
Mar 2, 2012 04:31 PM
jp1212pc
Jun 4, 2008 02:52 AM
anubisss
Mar 15, 2007 05:43 PM
