How do you set the pin with a fob?
Old Apr 24, 2008 | 03:12 PM
lecomte38's Avatar
lecomte38
Default How do you set the pin with a fob?
I don't have an owners manual. My 02 RK came with 2 fobs that work fine NOW but I saw a post about a pin to bypass the fob incase of a dead sender battery. How do you access/change this pin???
Old Apr 24, 2008 | 03:28 PM
rjrivero's Avatar
rjrivero
Default RE: How do you set the pin with a fob?
There is a procedure for this. As a matter of habbit, I won't post it in a public forum. Your dealer should be able to get you this info with no hassle. I reccommend getting an owners manual at least.
Old Apr 25, 2008 | 07:56 AM
lecomte38's Avatar
lecomte38
I gotta PAY my stealer to do it ???? nothing in my service manual on it..
Old Apr 25, 2008 | 12:31 PM
SK8ROD's Avatar
SK8ROD
its simple to punch the pin in if you dont have the fob on you:
1, turn on ign
2, straight away hold down both turn signal switches till the window in the speedo flashes
3, hit the left turn signal button the amount of times for the first digit
4, hit the right turn signal to confirm
5, hit the left again for the second and then the right to confirm etc etcetc
once all five filled in the bike will be ready to roll
if you want to change thepin to one of your choosing you need an assigned fob present if you PM me i'll tell you the procedure
pete
Old May 1, 2008 | 08:09 AM
lecomte38's Avatar
lecomte38
I GOT IT !!!! After a week of trying and reading countless threads with numerous WRONG directions I broke down and tried the local VERY NICE HD DEALER who photocopied the directions from the security owners manual for my 2002 RK. I post this because you can not reset the pin without your fob. For those with older security systems the procedure to reset the pin with the fob are:
1. ignition on-off-on-off-on
2. double tap left dir sw then immediately double tap fob.
3. push left signal once - red key will flash the number of times indicating the first pin number
4. advance (1-9) with the left dir to the new pin digit. (flashing key)
5. double tap fob to set first digit.
6. repeat steps 3-5 for the next 4 pin numbers (total 5 )
7. turn ign off.
check pin disarm:
1. set security ( slow flash red key )
2. run sw off
3. ign sw to acc
4. immediately hold both dir sw until fast red key flash
5. enter first pin number with left dir. then press right dir.
6 repeat step 5 for the next 4 numbers.
7. ign off you are set to go ( remember to switch the run sw on)
note: all numbers are counting the flashing red key. nothing changes in the speedo window.
Old May 9, 2009 | 09:40 PM
judyleu's Avatar
judyleu
Stage I
Default entering PIN to start without fob
The above worked for me as well on my 2005 Dyna Wide Glide. Thank you for posting!
Old May 10, 2009 | 01:47 PM
jmetro's Avatar
jmetro
sk8rod, the procedure you stated is for the hands free module not the push button fob used on an 02.
Hero
Sep 13, 2023 02:15 PM
'10 Wide Glide
Jul 11, 2018 09:49 AM
Dynalmadman
Aug 28, 2012 08:02 PM
SoonerSoftail
Aug 23, 2012 09:29 AM
0Nightster7
Jun 28, 2010 07:32 AM
