softtail battery going dead
Old May 7, 2008 | 08:03 PM
ridrkg's Avatar
ridrkg
Default softtail battery going dead
My son has a 05 softtail springer classic. It has a new battery. A couple of times in the last few weeks, the battery was flat enought that it wouldn't start. He posted on this forum a couple of days ago(bgizmo20). I charged the battery overnight. The next morning, I load tested the battery with an automotive tester(Sun VAT-40). It held a 180amp load at almost 11 volts for over 15 seconds. I checked the charging system. It charged about 30amps at 14.8 volts. I checked for a current draw. There was about a 40ma draw. When connecting the battery ground cable to the battery, there is a brief humming noise from the speedo, and the speedo needle moves downward for about 2 seconds. This is with the key off. Is this normal? Thanks ken
Old May 11, 2008 | 10:58 AM
Vikingnomad's Avatar
Vikingnomad
Default RE: softtail battery going dead
Check that you don't have a pinched wire somewhere causing a draw while the bike is off, re-trace your steps if you have made some recent mods/changes
Bone
Old May 11, 2008 | 08:23 PM
ridrkg's Avatar
ridrkg
Thanks Bone. I checked and there is about a 40ma draw with the key off. It seems to maybe be from the speedo. Most cars can handle a 100ma draw with no problem. The bike is ridden on a regular basis. Ken
Old May 11, 2008 | 09:00 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
If he has no security system, I wouldn't think there should be any current draw with the key off.
It is normal to get a light spark when reconnecting the battery but this is normally due to the charging ciruit and is only on initial connection.
I think you maybe need to look for a wire rubbed thru or somthhing like that. Since you are seeing a deflection in the speedo in the - direction, that circuit would be a good place to start.
Old Mar 17, 2012 | 12:52 PM
BigMarkStreetBob's Avatar
BigMarkStreetBob
I know this is an old thread so I assume you got it fixed. Was it a defective speedometer or something else?
Old Mar 18, 2012 | 09:17 AM
abners's Avatar
abners
2nd Gear
Old Mar 18, 2012 | 11:45 AM
BigMarkStreetBob
My speedometer on my 2009 street bob is causing a 56miliamp key off draw. I have not replaced it just unhooked it. I have a 16miliamp draw with it unplugged. Looking for a good deal on a used speedo. I assume the speedo is the problem but wonder why I have a 16 miliamp draw with it unplugged.
ronaldrwl
General Topics/Tech Tips
Sep 5, 2017 10:38 AM
TRacer
Mar 27, 2013 10:06 PM
Mixter
Mar 31, 2012 06:07 PM
SportyCustom
Apr 1, 2009 08:04 PM
flvrider
VRSC Models
Aug 24, 2006 08:41 PM
