Replacing Crank Sensor
Old May 22, 2008 | 01:40 PM
emillisk's Avatar
emillisk
Default Replacing Crank Sensor
Does anyone know what is envolved in replacing the crank sensor on a 2005 Fatboy?
Old May 23, 2008 | 01:06 PM
82SturgisFX's Avatar
82SturgisFX
Default RE: Replacing Crank Sensor
The first thing you want to do is make sure it needs changed.
If your motor kicks back on a no start (rolls back) this could very likely be a false reading. do you get a code,is it resetable?
I will say that if it does not have a separate plug,(two wire deutsch) then it will likely have a 5 pin connect in a 6 pin body (IIRC) the positioning of the two removed wires can be mixed up easily,but it does not matter.
does it still have residual magnetism ?
KennyPowerz
General Topics/Tech Tips
Jun 6, 2018 10:30 AM
dusturbd
Nov 17, 2013 12:23 PM
ilikesta
Exhaust System Topics
14
Oct 10, 2012 04:51 PM
jeffwest5599
Screamin Eagle CVO Models
Jul 22, 2011 08:20 PM
harvema
Apr 24, 2011 04:56 PM
