Engine Shuts Off When Warm
Old Jul 22, 2011 | 08:20 AM
jeffwest5599's Avatar
jeffwest5599
Default Engine Shuts Off When Warm
I have a 2005 SE Fatboy that is fuel injected with the 103 stock from factory. Recently, I have noticed when the bike gets warm, it will shut off. I can turn off the iginition switch and hit it again and it will start right up. It will also stay going if I keep a little throttle to it when it starts to do this. Any idea what this is or anybody had these issues before.
Jeff
Old Jul 22, 2011 | 11:30 AM
jeffwest5599
I pulled the codes and got the following:
P0261 Front Injector Open
P0263 Rear Injector Open
Any thoughts.
Jeff
Old Jul 22, 2011 | 08:20 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
possible crank sensor but it could also be power relay thats easier to change if that doesn't do it crank sensor. You can ck the crank sensor for this problem. get to the plug connector for crank sensor, disconnect it hook up an ohm meter should read around 750-800 ohms. remove the sensor end from crank case and put a heat gun/ hair dryer right on the sensor, watch the ohm meter for a couple minutes, if it goes to an open (infinity) you have a bad crank sensor
txphatboy
13
May 20, 2018 09:40 PM
smokeygold
Dec 26, 2014 08:37 PM
fishdo13
Jul 18, 2014 05:09 PM
HOTROD1300
Feb 26, 2014 03:03 PM
mamad
May 6, 2012 07:40 PM
