v.o.e.s.
Old Mar 12, 2005 | 06:46 PM
nutraman's Avatar
nutraman
Stage III
Default v.o.e.s.
I have just installed a new EV13 can in my 91 dresser.I previously had installed a EV3. The EV13 seems to work better for my riding style,but I could not get the bike to idle smooth after the cam change with the V.O.E.S. connected.I bypassed it and the bike idles fine.The only problem I seem to have now is a slight preignition as I ease onto the throttle at about 3000 RPM.I have a Compu-Fire ignition,but am not sure how to adjust the curve. The carb is a new Mikuni 42mm.I have a two into one Thunder exaust that is wide open.I could sure use some good advice.I don't want to hurt the motor after all this work.
Ken
Old Apr 12, 2006 | 02:09 PM
ThudMeister's Avatar
ThudMeister
Default RE: v.o.e.s.
Many of the Compu-Fire ignitions do not have adjustable or selectable advance curves.
Sounds more like you have a vacumn leak in the VOES or the hose, or possibly the timing is not set correctly.
If you have the VOES connected and it does not idle correctly, then all you do is disconnect the VOES and it starts idling well with out changing the timing, your timing was wrong to begin with - UNLESS of course you have a vacumn leak in the VOES or hose.
Doc Smoke BMCR
Jan 21, 2016 06:55 PM
jcsurf
Carburetor Related
Apr 30, 2015 05:27 AM
RidemyEVO
EVO
Jul 31, 2010 09:06 AM
Danny X
Ironhead
70
Jan 30, 2010 04:01 PM
kodd
22
Apr 16, 2009 06:44 PM
