Need a code explained
Old Jun 1, 2008 | 10:57 PM
elpoman's Avatar
elpoman
Default RE: Need a code explained
ORIGINAL: waterboyjack
this dtc is for ABS. according to manual ABS will still function fine however you may not have brake lights when applying front brake and YES , I would take it back to dealer if it did not clear after checking switch in hand control/front brake lever. Manual says can be caused by open circuit or short to ground. Have you had the switch box off lately??? pinched a wire maybe when reinstalling??? Sorry it took so long to respond, hope this helps.
Thanks for you help. I cleared the code, and well see if it returns, ifit dose,I well take it to the dealer. I have not done, anything to the brakes. I did just wash the bike, I wonder if water may have caused a short. My brake lights work.I'll keep and eye on it. Thanks again. I'll have to get the electrical manual.
Old Jun 1, 2008 | 11:08 PM
waterboyjack's Avatar
waterboyjack
That switch does have a rubber cover over it that the servvice manual "warns you about" several times "sa as not to tear it" ..... Maybe torn...
Cal516
General Topics/Tech Tips
Jul 2, 2019 09:59 PM
HSTWXMAN
Milwaukee Eight (M8)
Dec 4, 2017 06:16 PM
rideamap
Electrical/Lighting/Alarm
Sep 16, 2014 01:00 PM
bunotz
Oct 10, 2013 05:11 AM
tidefan60
Aug 7, 2010 09:48 AM
