Code P0572
Old Oct 9, 2013 | 05:55 PM
bunotz's Avatar
bunotz
Default Code P0572
My check engine light came on. I did the diagnostic check and the code P0572 appeared and I noticed my back brake light is constantly on, I hit the brake pedal and it still stays on. What does that mean, what type of part do I need to purchase and how hard will it be to fix it? Thanks
Old Oct 9, 2013 | 06:03 PM
chester1957's Avatar
chester1957
First try unplugging the rear brake light switch and see if light goes out. If it does replace the switch.
Old Oct 10, 2013 | 05:11 AM
Assegai's Avatar
Assegai
Yeah, sounds like the switch. After replacing it you might have to bleed the rear brake. The switch is closed when hydraulic pressure is felt on the brake line. If your brake is operating properly (releases) then the switch should be (electrically) open.
thumper89
May 2, 2015 03:19 AM
MachU
May 30, 2014 11:50 AM
ruckus4offroad
Mar 23, 2014 08:59 PM
frenchbiker
Oct 26, 2011 05:25 PM
rlzachary
Jun 8, 2005 10:51 AM
