Big problem NO START
Old Jun 6, 2008 | 01:43 PM
Ric27's Avatar
Ric27
Default Big problem NO START
Went to start the bike this mornin' and all I got was a little click in the switch under the seat marked with a red X and arrow in attached photo. I road last evening and after I came home I changed the ignition cover. That's it. Last week I had the starter off to fix a oil leak. Everything has been working fine sense. Please help if you can!!
[IMG]local://upfiles/44572/2968D84AF4324C829D9EA03FEB91427D.jpg[/IMG]
Old Jun 6, 2008 | 01:54 PM
rh8234's Avatar
rh8234
Default RE: Big problem NO START
General rule - always check the last things you worked on first.&nbsp\\; Go back and re-check all electrical connections and look for pinched or bare wires shorting out.
Old Jun 6, 2008 | 02:09 PM
Ric27's Avatar
Ric27
Will do, thanks.
Old Jun 6, 2008 | 03:07 PM
rh8234's Avatar
rh8234
When you find the problem, please do us all a favor, and post what it was.
Old Jun 6, 2008 | 08:49 PM
Ric27's Avatar
Ric27
Well I found the problem around 2:00pm todayand tried to post the solution but the site wasn't working right. It was the relay wire conection at the starter. It had come loose. pluged it back in and I was good to go. photo attached
[IMG]local://upfiles/44572/EE2AA877988B456193D60671111230EF.jpg[/IMG]
LQQK_OUT
Jun 2, 2015 10:31 AM
goallight
Jun 29, 2013 11:48 PM
Booey424
Jun 1, 2011 01:31 PM
Ric27
Jun 7, 2008 09:40 AM
locutus
Oct 9, 2006 02:32 AM
