electrical problem
Old Sep 9, 2006 | 09:18 PM
locutus's Avatar
locutus
Default electrical problem
i have a '91 electra glide. sometimes i try to start the bike, turn ignition on, everything ok. hit start switch, bike starts, then voltmeter falls to zero, no accesories, etc. pull side cover, jiggle black (ground) wire on starter relay, start bike, everything fine. this doesn't happen everytime i start the bike, say maybe twice out of ten times. sometimes just crusin along, everything goes to zero. same procedure. jiggle ground wire everything's ok. i've cleaned the connection to the relay. my wrench seams to think this is a bad stator, but i'm not convinced as it tests fine on my tester. should i just replace the relay, or am i just resetting it every time i jiggle the wire? should i be looking at something else?
Old Oct 1, 2006 | 06:50 PM
JAMES2's Avatar
JAMES2
Default RE: electrical problem
Did you ever find the problem?
[IMG]local://upfiles/17396/63B398578A7C4AA09EEE81920B484581.jpg[/IMG]
Old Oct 1, 2006 | 08:10 PM
glide's Avatar
glide
From what you say about the ground wire on the relay. it looks as if your problem lies there. Possible there is a break inside the insulation on that particular wire. Shouldn't be too hard to find the problem when it is in the no start condition.
Old Oct 9, 2006 | 02:32 AM
locutus's Avatar
locutus
yes, it took me a while, but it was the relay. got a new one from hd (updated part), and it did the trick. thanks for all your help a really appreciate it!
Mark_H
Aug 21, 2012 01:33 AM
woodsy75@roadrunner.com
General Topics/Tech Tips
Jun 4, 2012 08:42 PM
sbarnes489
Oct 30, 2010 10:22 AM
thedawg57
Jan 12, 2006 09:34 PM
CSR
17
Jan 15, 2005 06:37 PM
