How to repair wiring harness?
Old Jun 16, 2008 | 10:13 PM
Taterdog's Avatar
Taterdog
Default How to repair wiring harness?
I've got a bad signal wire on my tach.&nbsp\\; Pretty sure that's it since, for a couple of days if I turned the handlebars left or right, the tach would start working, then stop when I straightened out.&nbsp\\; Now the tach just doesn't work regardless of the handlebar position.&nbsp\\; I'm pretty sure I have a bad wire (pink in the manual), but don't want to have to replace the entire harness BIG job.&nbsp\\; One thread I read said it was a ten hour job for a dealer, and it would probably take me three times as much.
What's the best way to repair a bad wire in the main wiring harness?&nbsp\\; Just repull a new wire from the ECM connector to the tach connector and wire tie it to the harness?&nbsp\\; Not sure I would know how to find a broken wire if the outer insulation isn't damaged, so not sure it's worth taking the wiring harness apart.&nbsp\\; Maybe I'm wrong, though.
What have the rest of you done about fixing wiring harness problems???
Old Jun 18, 2008 | 09:03 PM
Taterdog's Avatar
Taterdog
Default RE: How to repair wiring harness?
bump
Old Jun 19, 2008 | 08:14 AM
lecomte38's Avatar
lecomte38
Are there any spare wires ( cruise control, aux switch, etc.)&nbsp\\; that you could use? or run an external wire.
Old Jun 19, 2008 | 06:35 PM
Taterdog's Avatar
Taterdog
Not aware of any spare wires.&nbsp\\; That sure would make it easy to check/fix, but if everything had a spare, we'd be riding 1500 lb. bikes! &nbsp\\;
Carl '69
Jun 13, 2017 10:16 PM
Tony Downers
Shovelhead
Aug 25, 2015 03:20 PM
firstrock
Aug 6, 2012 03:45 PM
Benny70hemibird
Jan 14, 2010 03:26 PM
Taterdog
Jun 20, 2008 06:41 PM
