PC III install comments
Old Jun 22, 2008 | 09:58 PM
marksv4's Avatar
marksv4
Default PC III install comments
Just installed my Wild Pig slip ons, Big Sucker a/c and PC III mapped by Fuel Moto.
&nbsp\\;
Couple of things....
&nbsp\\;
My plastic tray&nbsp\\; which holds the ECU on my 08 RK w ABS would not fit back the way it used to after turning the battery pos. cable 90 degrees, installing the PC III plug to the wiring harness plug. &nbsp\\;There simply is no room. I tried and tried to force the wiring loom back towards the frt of the bike to gain room. Ended up trimming the plastic tray.&nbsp\\; The pdf file for install is a little confusing, some things like the O2 sensor install are not included with the ABS bike section.
&nbsp\\;
Cd that came with the kit&nbsp\\;is just as confusing as it will not self install, is their a .exe file somewhere?&nbsp\\;
&nbsp\\;
Where do you find the section in the CD about zeroing the throttle etc.?
Wish the EXACT procedure was outlined somewhere. Crap I am glad the bike started up and runs great, was a little worried.
&nbsp\\;
What do you do with the extra&nbsp\\;o2 wiring that is hanging from the exhaust out front. Too bad you cant just remove it and put a plug in the exhaust where the sensor goes..&nbsp\\;...
&nbsp\\;
Not many Hd owners up here in Vancouver B.C. even know what a PC III is..........&nbsp\\;
Old Jun 22, 2008 | 10:58 PM
hardhead's Avatar
hardhead
Default RE: PC III install comments
I&nbsp\\;left my O2 sensors in the head pipe but did use the o2 eliminators. Use this link and follow the directions on tutorial #10 to set throttle position after installing the software which can be downloaded there too. Good Luck.
&nbsp\\;
http://www.powercommander.com/powerc...downloads.aspx
Old Jun 22, 2008 | 11:46 PM
arodgers's Avatar
arodgers
ORIGINAL: marksv4
What do you do with the extra&nbsp\\;\\\\\\;o2 wiring that is hanging from the exhaust out front. Too bad you cant just remove it and put a plug in the exhaust where the sensor goes...
You can...
http://www.racepartsolutions.com/pro...rod=RPS-o2plug
Cost me $14.95 total for two of them shipped.
04ctd
Jul 23, 2008 07:58 AM
dshroyer
Shovelhead
Jul 15, 2008 07:31 AM
harry.b
Jul 4, 2008 09:02 PM
hotpursuit
Jun 21, 2008 06:30 AM
porkster
Jun 20, 2008 08:34 PM
