need help programming sert
Old Jul 3, 2008 | 09:14 PM
puma's Avatar
puma
Default need help programming sert
&nbsp\\;When I try to remap my ECM I get as far as "program ECM" it loads up to 25% and then I get "unable to install bootloader"&nbsp\\; Can anyone explane what the problem is.&nbsp\\; Thanks
Old Jul 3, 2008 | 11:39 PM
Doc 1's Avatar
Doc 1
Default RE: need help programming sert
Are you using a usb adapter or are you using Vista ?&nbsp\\; Neather one of these will work very well for you.&nbsp\\; When the error comes up about the bootloader the ECM is getting information out of the order it needs to get it so it protects it's self and stops there. You need windows XP and a serial port to work with the SERT without problems.
Old Jul 4, 2008 | 12:11 AM
puma's Avatar
puma
Yes I am using a serial port adapter, I guess that's my answer. Thanks Doc
Old Jul 4, 2008 | 12:18 AM
puma's Avatar
puma
I mean usb adapter&nbsp\\; Thanks
Old Jul 4, 2008 | 12:25 AM
Doc 1's Avatar
Doc 1
Yea .... the usb just loads information in a random way quickly, the serial port loads the information in an order the ecm needs. Now there is a adapter made by Bilkin that will work but I forgot the number...it isn't cheep.
Old Jul 4, 2008 | 12:26 AM
tunaman's Avatar
tunaman
ORIGINAL: Doc 1
Are you using a usb adapter or are you using Vista ?&nbsp\\;\\\\\\; Neather one of these will work very well for you.
&nbsp\\;
Realizing that this is specific to SERT, which I have no experience with,&nbsp\\;I've also seen lots of claims that Vista and the USB-serial adapters won't work... that is largely incorrect. I was able to interface with the ThunderMax using my laptop running Vista, coupled with a USB-serial interface from Rat Shack earlier today. Most probably didn't have the joys of working with COM ports to get their modems and other devices to play nice, so they don't understand about conflicts and resolution. When I first coupled the device with the laptop, Vista automatically set the COM port to 4 which couldn't detect the module. I changed it to use COM 7, and it was able to interface and modify the device without further incident. It also worked fine previously with the PC III.
&nbsp\\;
Perhaps Harley's SERT is more antiquated or less sophisticated, but there is no physical reason it shouldn't be able to work with it.
&nbsp\\;
Roger
Old Jul 4, 2008 | 07:02 AM
Doc 1's Avatar
Doc 1
ORIGINAL: tunaman
ORIGINAL: Doc 1
Are you using a usb adapter or are you using Vista ?&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; Neather one of these will work very well for you.
&nbsp\\;\\\\\\;
Realizing that this is specific to SERT, which I have no experience with,&nbsp\\;\\\\\\;I've also seen lots of claims that Vista and the USB-serial adapters won't work... that is largely incorrect. I was able to interface with the ThunderMax using my laptop running Vista, coupled with a USB-serial interface from Rat Shack earlier today. Most probably didn't have the joys of working with COM ports to get their modems and other devices to play nice, so they don't understand about conflicts and resolution. When I first coupled the device with the laptop, Vista automatically set the COM port to 4 which couldn't detect the module. I changed it to use COM 7, and it was able to interface and modify the device without further incident. It also worked fine previously with the PC III.
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
Roger
&nbsp\\;
If you have no experience with the SERT Roger but still insist the usb and vista will work with it sure makes you look foolish!
Old Jul 4, 2008 | 08:50 AM
tunaman's Avatar
tunaman
ORIGINAL: Doc 1
&nbsp\\;\\\\\\;
Thank you for the personal attack sir, and on Independence Day no less. Not knowing my qualifications makes you look judgemental, among other things.
&nbsp\\;\\\\\\;
IF IT IS WRITTEN TO USE THE RS232 INTERFACE SPECIFICATIONS, THERE IS NO REASON THAT THIS STANDARD RS232 INTERFACE WON'T SUPPLY THE REQUIRED BUS, PERIOD. That is the statement I made, and I'll stick to it.
&nbsp\\;\\\\\\;
I've seen numerous posts indicated that the PC III and TMax won't work with it as well, and it is largely from folks unfamiliar with the vagaries of RS232 interface configuration in relation to memory and IRQ conflicts. Those of us who have been working with computers for 20 years or more have likely had to fight through these conflicts time and again. I have a degree in electronics along with 5 years work experience, to the component level, and more computer certifications than I can name to include CNE, OS/2, IBM Lan Manager/Lan Server, MCSE, etc., and have been in IT for over 20 years working for Countrywide Funding, Chevron and Kaiser Permanente, so it is not an area&nbsp\\;\\\\\\;unfamiliar to me.
&nbsp\\;\\\\\\;
So please elighten me as to what is specific and unique to SERT that violates the RS232 interface standards? Please don't hesitate to be specific, as I believe I'll be able to grasp any technical details you wish to share?
&nbsp\\;\\\\\\;
Happy Independence Day,
Roger
Old Jul 4, 2008 | 08:55 AM
IndyRider's Avatar
IndyRider
Puma, DOC 1 is correct.&nbsp\\; I tried the Bilkin and still it would not always work.&nbsp\\; I ended up getting an old desktop PC with XP and a built-in serial port, put it in the garage&nbsp\\;and the problem was solved.&nbsp\\;
&nbsp\\;
&nbsp\\;
Old Jul 4, 2008 | 09:00 AM
IndyRider's Avatar
IndyRider
Tunaman, when you have success with VISTA, USB adaptor and the SERT let us know.&nbsp\\; Until then you are just&nbsp\\;stating theory.&nbsp\\; In theory it should work but does it?
