ignition timing 1967 electraglide
Old Jul 7, 2008 | 08:55 PM
cady1's Avatar
cady1
2nd Gear
Default ignition timing 1967 electraglide
Hello I would like to talk to someone familiar with the location of timing marks.
Old Jul 7, 2008 | 09:19 PM
markymark02's Avatar
markymark02
Default RE: ignition timing 1967 electraglide
Hey welcome to the forum, I see your getting the run around, I'm assuming you have a pan-shovelhead, I might be able to help depending on what you need to know, if not I would try posting in the classic section, in that section you can post on panhead or shovelhead, they all have their own section, goodluck!!
Old Jul 8, 2008 | 01:09 PM
60wt's Avatar
60wt
cady1....I have a 68 shovel..i gave up on the timing marks long ago.. I made a little rod to put in the cylinder through the spark plug hole to set up the piston 7/16' before TDC on the compression stroke, then with the points already set, advance the point cam lobe, and useing a multi meter, or Thin piece of paper, snap the points open and/or slide out the paper and snug her down, you should be set to go..
98hotrodfatboy
Aug 22, 2018 01:48 PM
Dergs713
EVO
17
Sep 8, 2017 09:05 AM
gil57usa
Shovelhead
Oct 16, 2016 07:33 PM
wscott62893
Jun 27, 2014 06:11 AM
CTP
Ironhead
Sep 7, 2007 01:13 AM
