SERT map request
Old Aug 12, 2008 | 09:25 PM
puma's Avatar
puma
Default SERT map request
Does anyone have a map for
'07 FLHT
Big Sucker
V&H Pro Pipe
SERT 4.6.2
I live in northern Alberta Canada where dyno tuners are scarce & expensive, one charges $135 hr he said the last one took him 11 hrs, the other place said it took 14 hrs. I'm trying to get a map from Mike @ Latus but they don't have one for my set-up. I'm using the sert map #78 but I am getting a lot of knock on acceleration. Any help would be appreciated Puma
Old Aug 12, 2008 | 10:42 PM
Spike_96's Avatar
Spike_96
11-14 hours?? WOW!! If your knock sensors are on, timing may need to be retarded. Other factors are, Heat and fuel octane to name a few.
Good Luck.
Old Aug 14, 2008 | 09:02 PM
puma's Avatar
puma
I increased the CLB to 762 (Nightriders site suggested this) I decreased the timing 2.5 degrees in the 2500- 3500 rpm @ 80-100 MAP. It helped a little but I think the problem is more than timing & thats kinda beyond my comfort zone. Thanks
Old Aug 14, 2008 | 10:07 PM
murphdog's Avatar
murphdog
Why don't you try calibration 78, 176PZ005-A1, from the newer version 4.7.7 software? Timing is quite a lot more conservative in the 70-100kpa cells...as much as 9 degrees less.
You can download version 4.7.7 here. http://www.sendspace.com/file/q7d973
Bachus
Aug 25, 2012 09:06 AM
Shark.Glide
Sep 8, 2010 01:16 AM
cwalms
Jun 15, 2007 12:59 AM
rpt63
Feb 16, 2007 06:28 PM
twstdharley
Exhaust System Topics
Feb 6, 2006 11:18 PM
