SERT maps - Injector Size
Old Mar 24, 2006 | 01:44 PM
doomie19's Avatar
doomie19
Default SERT maps - Injector Size
Hi all,
Just got my SERT today and had a question on the maps. This is the new "E" version and it has maps for both 8* and 25* injectors. I was looking at my basic setup (SE A/C, SE slip-ons) and the 25* map looks identical to the 8* map aside from the rear cylinder VE table. Under the ECM Tuning Constants, the injector setting is 3.91 for both. Does anybody know if this value is used as input? I'm curious why it would still show the 8* flow rate on the CVO injectors. [sm=confused06.gif]
Old Mar 31, 2006 | 04:23 PM
fiugzel's Avatar
fiugzel
Default RE: SERT maps - Injector Size
I'd like to ask the same question. Come on you SERT experts.. help us out here.
Old Mar 31, 2006 | 08:03 PM
chopperchuck's Avatar
chopperchuck
yes,you should change the 3.91 to 4.89 in the tuning constants table. the sert will do the rest....
Old Apr 10, 2006 | 05:12 PM
dashiell's Avatar
dashiell
i tried that change and the 4.89 did not work. I changed the constant back to 3.91 and it worked great. and yes i have the 25 dgree injectors
cjike
Jul 3, 2007 07:34 PM
double_d90
Apr 21, 2007 09:41 PM
Indianspringsaz
Sep 29, 2006 05:46 PM
ScottFLHX
Jun 2, 2006 11:21 PM
MikeO
Apr 17, 2006 05:08 PM
